Help to generate PWM
Hello all
I'm quite new in using Labview and I need help to generate PWM with frequency 20 kHz and changeable duty cycle
I need generate this PWM via  digital I/O NI 9403 and cDAQ-9184....
thanks
(2,826 Views)
This Forum is for help with developing LabVIEW code yourself.  There is another Forum if you want to hire a Developer.  There is an NI Tutorial on generating PWM signals here as part of the Getting Started with NI-DAQmx series.  If you try developing your own code and "get stuck", come back here, attach your VI (so we can see what you are doing and how we might help you), and you'll get more help.
(2,812 Views)
