Help reg. Wave form chart
How to display the active cursor X-Y coordinate points on the wave form chart, the X-Y points should be displayed on the graph itself.
like the picture i attached
thank you
sasi
(2,673 Views)
Hello
One way could be as follows: there is a property node for active cursor called "cursor name"
Convert the coordinates to string and use then as input to that property node.
You can place the name relative to cursor to get exactly that you want to.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,663 Views)
