Help needed to build Exe and Installer in LabVIEW 2009
Hi all,
Can someone help me build an executable and a installer for the attached code. I have tried hard with no luck.
Any help would be appreciated
KM
(3,721 Views)
Do you have the LabVIEW Professional Development System? If not, you're out of luck unless you purchase the Application Builder license seperately.
If you have Application Builder, this should have all of the information you need.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,718 Views)
Hi James,
Thanks for your time.
I have LabVIEW Professional Development System installed. I tried the steps mentioned in the document. I get this error when i try to build the executable. I dont know how to get rid of this, inspite of all the sub vi's are running fine.
KM
(3,691 Views)
@KevinKM wrote:
Hi James,
Did you do as that message box told you and open up the VI in question?????
(3,676 Views)
I opened the file and verified the vi. its running fine, there are no missing sub vi's.
I wonder while configuring the executable properties. In the category -> Source files->Project files. I have Main VI, Xcontrol(Selectable listbox 2009)  and other sub VI's. I will add the Main VI to the Start up VI's. I will add the main vi of XControl and other sub vi's to the Always Included. Is there any other vi's of  XControl that i need to include in Always Included Box to make this work.
KM
(3,620 Views)
