Help needed for using Waveform graph indicator
I am making a VI that plots y=Ax^2 + B, where all the variables are controls, also the Vi should use front panel control to enter the no. of points N to eavaluate the polynomial over the interval x0 to x n-1. I want to plot y vs. x.
This is where i am getting confused?Smiley Sad does N means the no. of loops(for loop) i want the VI to run. i am not able to plot y vs. x???
Please help with both these problems.
Thanks for any help..........
Message 1 of 11
(4,728 Views)
attached is the VI...........i am using so far..
Message 2 of 11
(4,723 Views)
Is this a school project?
X will vary, so it should not be a front panel control, but calculated from the iteration terminal of the loop.
A and B should go outside the loop, they should not change during loop execution
Inside the loop calculate x and y for each [i]. They will turn into arrays at the loop boundary, containing the set of X-values and Y-values for the graph. Now use an xy-graph to plot y vs x.
See how far you get. 🙂 Check the online help and the LabVIEW example finder for more ideas.
Message 3 of 11
(4,719 Views)
Thanks for the help. I think i got it...........
Message 4 of 11
(4,715 Views)
hi,
I got confused again, as to what i am using is correct or not? please let me know whether it is correct. My confusion is about the values of "x".
Thanks again,
Message 5 of 11
(4,710 Views)
at the transit of the for loop an array will be created with the value of the For Loop counter (number of iterations)
regards
timo
Message 6 of 11
(4,705 Views)
First of all, you should remove the timing node. There is no need to slow down the calculation. 😮
Currently, you use [i] directly for x, which is often a bit limiting. You should calculate and x based on [i] instead. (for example" x=0.1*[i] or x=[i]-50, etc. depending on the x-values you want.)
Of course a much simple version of your code would be:
  1. Use the Ramp Pattern to generate the desired x values (inputs are: start x, end x, number of points).
  2. Use the polynomial evaluation function with the x-array and the [ABC]-array to generate the y-array.
  3. graph it! Just bundle the x- and y-arrays and feed the cluster to the xy graph. No need to go through the express node.
Happy wiring!
Message 7 of 11
(4,697 Views)
Thanks for the help..
Message 8 of 11
(4,689 Views)
Thanks..
Message 9 of 11
(4,619 Views)
i got that, could you please chek it for me.
Thanks...
Message 10 of 11
(4,686 Views)
