Help how to write ARP command on TCP
Help or advice needed...
In my application I'm using an Access Point /Router that is connected to the computer with the LV application (exe compiled) running on it. At a precise moment I need to release a specific IP address and it's associated MAC address from the TCP connection...
The "arp -d nnn.nnn.nnn.nnn" (n=IP address) has the right action and releases the wanted IP address when send from the dos screen , but when I want to build this command in my labview application via a TCP Write VI, I have nothing happend. Did someone faced that kind of problem ?
Thanks for help...
HaemoPhil
(4,669 Views)
Why don't you use the system exec function to run the dos command.
(4,664 Views)
Dennis,
Thanks for quick answering... But where can I find this function... what VI ... I never used it before
HaemoPhil
(4,659 Views)
It's on the Communication palette. Anytime you're trying to find a function, you could search for it. On the functions palette, there's a search button.
(4,656 Views)
Thanks a lot Dennis...
I've got it and it works fine now....
You were a great and precious help...
regards
HaemoPhil
(4,654 Views)
