Help files
I want to create some help files to be accessed from the menu in
labview. Does anyone know of an easy way of doing this, I've had a look
around and it seems you need specialist packages to create the right format.
Martin.
(2,938 Views)
Martin Stanley wrote:
> Hi,
> Regards,
> Martin.
Labview will generate some source files that you can use,
but you need a help compiler to make them work.
Check the online manual for "Help->Creating" to find
the recommended compilers.
Other options include using the buit in help window,
and launching a web browser with your help docs.
I have used the second method with some success.
Kevin Kent
(2,938 Views)
