Help converting from 7.X to 6.1
I've attached an instrument driver that was created in 7.X. I only have 6.1 and was hoping someone could convert this to 6.1 format as none of the VI's will open. There are no express functions involved so I think it should be fine in 6.1
~tony
(2,474 Views)
I  have attached a zip which contains the converted llbs (from 7.0 to 6.1).  The VIs which stand alone in the zip you attached use testand.llb, which I believe ships with testand 2.0.1, so those won't be useful to you unless you have testand installed.  In any event, hopefully the converted llbs will give you what you need!
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(2,444 Views)
oops... testand in the previous post should be TestStand :)
Best Regards,
JLS
Best,
JLS
Sixclear
(2,442 Views)
