Help Required
I am using LV 8.6. I am stuck with some issue related to events. I am using a menu called "Test" in my application. Under "Test", I have "Run","Stop","Pause" menu items.I am creating this menu in run time in my application. When I click "Run", my tests will start.My test consists of the following steps:
1. I have to poll for some switch action
2. if it is as expected then i have to wait for some time, say 1hour.
3. Then I have to send some range of frequencies to the UUT and read back the signal from DMM/Counter for each frequency.So I have kept this in while loop.(I have total 32 UUTs, Step 2 has to be repeated for all the user selected ones.)
4. I have to poll for some switch action,
5. if it is as expected then i have to wait for some time, say 1hour.
6. Same as Step 2.
while performing the above actions if the user clicks "Stop", then my tests should stop. For "Pause", i should be able to hold the tests in the same state and then should be able to continue from the same point in the future.
I am using case structure for handling menu events. From "Get Menu User Selection VI", i am reading the user selected menu item and executing that particular structure.Here i am facing issue.When I am inside the "Run" case, if user selects "Stop"/"Pause", Stop/Pause case is executing only after the "Run" case is completed. What I understood is after every step in my test , i have to continuously poll for the menu selection. But I am not getting how to implement this in my code.  Because I have one case structure ( with one while loop outside ) for handling all my menu items. If Inside "Run" case, for each step if i have poll for the menu item means again i have to keep one more case structure then it will become a mess...
Can any one suggest what will be the better approach to handle this..... Any help will be greatly appreciated..
Harika
(3,531 Views)
Hi harika,
What you can do is,pass reference of Pause and Stop buttons inside Run case.Hopefully you are running a subvi inside it.
If yes, then you can access events(of pause and stop) inside that subvi.
Place a event structure and you can pause and stop execution.
Best of LuckSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,520 Views)
Hi Gaurav,
Thanks for your suggestion. But unfortunately i didnt understand clearly what u r trying to explain.
I got an idea of using "State Machine Architecture" for this scenario. Please let me know whether this approach works fine.
Harika
(3,513 Views)
Yes harika state machine architecture will solve your problem.
About what I said in the last post: if you did not understand, Check the example code attached with this post. This will show you how you can access
events of main vi into sub vi. I don't have time to do it properly.But it will definitely give you an idea.
Gaurav k
CLD Certified !!!!!
(3,504 Views)
Yes you can go for the State machine arcitecture, use the notifiers for getting the events and you can use a parallel loop to execute the acquisition etc.,
Smiley Wink
(3,503 Views)
