Help!!! Labview Exe compiled works a while, and shortly after stops running and gets dead and static. .
Hi friends, I'm doing a project in labview 2016 that worked everything Okay before, but for a while, he is been presenting a pretty weird failure.
When I execute in labview the code works without problems, but when I compile and execute the 'exe' it works a while, if I close and open again it is no longer working, the visual part opens but the buttons and functions do not execute, it dead.
Another thing, if I rename the directory where the 'EXE' compiled it is, it goes back to running for a while and then it stops again. If I keep repeating this renaming the directory it works again and then stops.
Remembering that in labview the code works without problems, the strangest that less than 2 weeks ago was normal.
Have you been through this? could help me, I'm almost crazy. Thank you.
Message 1 of 12
(4,689 Views)
what does the program do?
Message 2 of 12
(4,661 Views)
is a code that receives information about the port state of a microcontroller PIC18f4550, and also it triggers the ports. It worked okay at least two weeks ago, I did not change anything in it and should work as before, but it does not work. Until the old compiled does not work right.
Message 3 of 12
(4,634 Views)
When you start up the .exe and it doesn't seem to be working, I'd try debugging the executable using the LabVIEW IDE. You can debug the .exe just like you would a .vi, by starting LabVIEW, opening the "Operate" menu, and choosing "Debug Application or Shared Library...". Here are instructions: http://digital.ni.com/public.nsf/allkb/8DA679805915DE40862572D5007B2F70
Message 4 of 12
(4,631 Views)
 Thanks arteitle, for the reply, I'll do this. soon post here
Message 5 of 12
(4,628 Views)
Hi, I did the procedure, but when I open the development platform the error does not occur and everything works ok, but if I open the executable alone the error presents.
Has an observation, I did the test installing on other PCs, the error does not present. Only occurs on the PC I am developing, should I format the PC?
Message 6 of 12
(4,619 Views)
No need for such a drastic step yet. I was suggesting that you should start the .exe in whatever way causes it to malfunction, then start LabVIEW and try to use it to debug the malfunctioning .exe. Are you using a COM port through VISA in your application to talk to your PIC? Could it be that something else is opening and holding the COM port and not releasing it for your .exe to use?
Message 7 of 12
(4,610 Views)
I use the serial USB communication. I made the connection in debugging, but even when debugging the debugging also hangs and no more options open the blocks, seeerro.png
Message 8 of 12
(4,607 Views)
Connecting to the executable is just the first step, then you need to look into the block diagram and see what's happening that shouldn't be, or not happening that should be. Can you find a place in the block diagram where the program is getting stuck?
Message 9 of 12
(4,596 Views)
I did the test now, following step by step of the execution in the block, but he executes everything and simply does not expect anything practically, it is as if he were dead.
Not even pressing "Abort execution" does not work
Message 10 of 12
(4,590 Views)
