Help! How to creat this INPUT control?
as tree controlas tree control
 This control is usefull and can contain boolean , numeric values, paths, etc., how to  implement it?
 thanks.
(1,886 Views)
Is this screen shot from NI MAX?
I don't believe it's created by LabVIEW.
You can create similar controls with a .Net table.
https://forums.ni.com/t5/LabVIEW/OpenSource-Project-for-a-NET-Datagrid-for-LabVIEW/m-p/3183555/highl...
Haven't seen anyone do it with a tree yet.
George Zou
(1,847 Views)
Thanks for your reply!
Yes, it's NI MAX's screen shot
I read that post and it isn't the effect I want.
I've seen that effect once, so I'm pretty sure it works, but I don't know how.
>__<
(1,838 Views)
Nice project, but I am not sure it allows different types in the same column as OP wanted.
From the GitHub page, it seems the datatype configuration is common to the whole column.
(1,831 Views)
yeah!
You know me!!
I want the second column has different datatype.
And the first column can be collapsed and expanded.
(1,823 Views)
There is no way to do that in pure G.
But you can overlay any datatype on the tree,
and only show up when mouse hover;
convert the data to string for the tree when mouse leave.
Or you can create your own ActiveX/.Net ctrl,
and call it in your VI.
George Zou
(1,809 Views)
Accepted by topic author 威海半道红
hi,thank you, zou;
I think your way can work !
And I sow an example by NI vision named "Advanced Functionality with Attributes.vi".
We can use it as a base VI.
(1,770 Views)
