My system:
Win XP
LabVIEW 8.0
SIT 3.0.1
Matlab 7.0.1 R14
MS Visual Studio 2005
Hope any one can help out here! Thanks!
I want to convert a .mdl file into DLL then I can use in LabVIEW for certain stand alone application. However, I always got the following two errors after I clicked 'Build':
Build Error:
Error using ==> RTW.makertw.make_rt
Error using ==> rtw\private\issue_inv_comp_env_val_error
Invalid setting for environment variable MSDevDir or DevEnvDir.
The setting is: '[c:\program files\microsoft visual studio 8] \common7\ide'
You can verify the setting by checking for the existence of:
%MSDevDir%\..\vc\bin\vcvars32.bat (for Visual C/C++ 5.0)
%MSDevDir%\..\..\vc98\bin\vcvars32.bat (for Visual C/C++ 6.0)
%DevEnvDir%\..\tools\vsvars32.bat (for Visual C/C++ 7.0)
You must define MSDevDir or DevEnvDir to be:
set %MSDevDir%=<VisualRoot>\sharedide (for Visual C/C++ 5.0)
set %MSDevDir%=<VisualRoot>\common\msdev98 (for Visual C/C++ 6.0)
set %DevEnvDir%=<VisualRoot>\common7\ide (for Visual C/C++ 7.0)
This error may be due to an invalid preference file:
C:\Documents and Settings\Owner\Application Data\MathWorks\MATLAB\R14\mexopts.bat
Please run "mex -setup" at the MATLAB prompt to correct
Model Error:
Error building Real-Time Workshop target for block diagram 'SinWave'. MATLAB error message:
Error using ==> slbuild
Error using ==> RTW.makertw.make_rtw
