Help! Can't open Labview program with MATLAB codes !!!
They used to work! But today I just can't open any LabView program with MATLAB codes in. This also happened some time ago, but after a day I tried again, it went back to normal. Can anyone help me fix it? Many thanks !!!
(3,168 Views)
Hello BLpig,
Thank you for your inquiry regarding problems opening a VI. It sounds like a VI containing MATLAB code will not open in LabVIEW. This problem can happen when using LabVIEW 7 on a Windows 2000 machine. Assuming this is your setup, the following link is a great resource when dealing with this issue.
http://digital.ni.com/public.nsf/websearch/4475BC3CEB062C9586256D750058F14B?OpenDocument
Other resources similar to this can be found on the ni.com website by clicking the support tab at the top of the home page. Then search for �open vi matlab� from Technical Resources at the top of the page or topics similar to this. I hope these resources help. Let me know if I can further assist you.
Shea C.
Applications Engineering
(3,168 Views)
Thanks so much. It works for me by replacing the old dll file.
(3,168 Views)
