Hello
I'ts possible to omit the Labview symbol from
the title bar in a VI ?
T.U.
(5,740 Views)
You can hide the title bar when running the vi.
In LV 6:
-pop up on your icon's vi
-select window appearance
-select customize
-the first option is window has title bar, if you uncheck it, your vi want show the title bar when running.
Happy Easter !
(5,739 Views)
Hello
I like to keep the title bar, but to remove only the LV symbole.
Regards
(5,739 Views)
Then, I don't actually know how to do.
Check on the Dev zone library, there should be an example I've seen time ago for controlling the properties of windows and also title bar, maybe it may help.
I'll try to recollect this example, in case I'll send you.
(5,739 Views)
You can change the LV icon to an icon of your choice with tools
such as Microangelo http://www.impactsoft.com/
or AX Icons http://www.axialis.com/index.html
Open labview.exe from the tool and edit or replace the icon.
If you are using Application Builder you can change the
icon in the "Application Settings" tab, "Custom Icon".
I don't believe it is possible to remove the icon totally.
Alan
"Mor" wrote in message news:5065000000080000008E1A0000-986697009000@quiq.com...
> Hello
> T.U.
(5,740 Views)
Mor wrote:
> Hello
> T.U.
You can change the titlebar icon (the one on the left end of the
titlebar)
at run time in LabVIEW. Download "G Toolbox" at:
http://gtoolbox.yeah.net
There is a VI in G Toolbox, "Titlebar Icon", which will let do what you
want in LabVIEW environment or in Application.
(5,739 Views)
As others say, to change the icon in the title bar, you must change the icon of labview.exe (if in development mode) or the executable resulting (if built in app). You can achieve this using different methods, as Icon editors and LabVIEW app builder (if version 5.1 or later). If you want to totally remove the icon in the title bar you can create a transparent icon and apply it to your application, the problem is that the app itself will have the transparent icon.
(5,738 Views)
