Hello! I need help witt my student project.
I had to make virtual digital ocilloscope - with:
-Up to 4 channels selection
-Sampling frequency (10 - 100Hz) (for DC signals)
-Number of samples per cycle (100 - 1000 samples)
-Trigger
It works with my NI-PCI-6229 card, but now I have to make it work with Advantech PCI-1711 card.
Any help?
(2,679 Views)
Each and every one of the DAQmx functions will have to be replaced with Advantech functions. It's unlikely that there would be a one to one relationship. You will have to study the Advantech functions in it's library.
Your VI is also setup to perform only a single acquisition unless you use the Run Continuous button. Do NOT use this special debug mode for operation. Put a while loop around your code.
(2,674 Views)
