Hello, I have some problem for my aplication
I have a VI "Page_Principal_modif1", when I run my application, I see the menu File, Window, .., Entrées Consignes, etc..
In my case, I'd like to enter the différents values in the sub vi Entrées Consignes and I save them in the cluster.
My probem is , I' d like to display the same values in my VI "Page_Principal_modif1", What I do? I create one solution but it is not good.
Can you help me , please?
My second problem is, when I enter the différents values in the sub vi " Entrées Consignes", I' d like to save the values enter until someone change it.
Thanks you for your help.
(2,501 Views)
To get data into multiple VIs executing at the same time you will need to use either global variables or a synchronization data type like a queue or notifier. Please see the links below for more information about these structures.
What Is a Queue?
What Is a Notifier?
Global Variables
(2,442 Views)
