Having trouble opening connections and reading from Bluetooth devices.
As the title states, I am having trouble opening connections and reading data from a Bluetooth device. We are using a PDA to communicate with LabVIEW. First, the Bluetooth Open Connection VI displays a timeout error half of the time. Second, when it does open, it does not read what the PDA is sending. Third, if it does allow an open connection, it will not do it a second time unless the devices are turned off.
I also have another related question. I am using a Linksys Bluetooth USB adapter, and the driver is proprietary. Labview requires the use of a Microsoft driver, and we are having problems going back and forth between the drivers. What Bluetooth receiver would you suggest using? The reason I ask is the fact that you have Bluetooth examples of client VI's. Therefore, you must use a similar device. Thank you for your time.
-Jon
(2,594 Views)
Hi Jon,
I'm not sure what Bluetooth receivers were used to verify the functionality of the VIs. However, I still want to help you solve your issue. Please make sure that you are running the shipping examples and let me know what version of LabVIEW, what PC OS and what PDA OS you are using. Does the Microsoft driver work for your Bluetooth receiver if you uninstall the Linksys driver?
With your answers I'll do my best to help you out.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,577 Views)
