04-19-2010 10:43 AM
So, I have tried to code this to where it creates the equation I need inside of a for loop (r^2=((A^2)(B^2))/((A^2sin^2phi)+(B^2cos^2phi)) but for some reason I can't set the bounds (0 less than equal to phi less than equal to 2 Pi) or connect it to a xy graph.
Any suggestions?
Chod
04-19-2010 10:51 AM - edited 04-19-2010 10:59 AM
The output of you FOR loop is a single number, not all ellipse. Your FOR loop calculates the same value N times. Try to involve the iteration terminal. 😉
Check the help on what datatypes an xy graph accepts. I recommend using complex numbers.
Note that the rotation is easier using complex multiplication (details).
