Has anyone tried to use labview to measure tcp/ip throughput between 2 computer using labview?
I was wondering is LabVIEW can be used to measure throughput of the ethernet connection between 2 computers. Data in Mbps such as uplink and downlink on the connection.
(2,771 Views)
I've included a link to an article for determining the maximum TCP/IP transfer rate in LabVIEW.  You can download the example that is included in the article.  This example VI measures the communication from a real-time target to a host PC, so you'll need modify it for your application.  Please let me know if you have anymore questions, thanks!
Measuring the Maximum Amount of Data Sent Out of a Real-Time Target Device
(2,750 Views)
