Has anyone managed to program a Wago 750-650 module attached to a Wago 750-341/841 controller
I'm planning to use 2 Wago 750-650 modules (serial to ethernet converter) attached to either a Wago 750-341 or 841 ethernet controller to communicate with a vacuum controller which uses a serial interface.
I wonder if anyone has accomplished this? I have written a small VI using MODBUS commands to try and achieve this but I am unsure how to input commands of longer than 3 bytes and it seems that it is not working yet.
Any tips or help would be welcomed.
Keith.
(4,083 Views)
Hello Keith,
Does this KnowledgeBase (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0QgCAI&l=en-US) help you further?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,049 Views)
Hello Keith,
Does this KnowledgeBase (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0QgCAI&l=en-US ) help you further?
Kind Regards,
(4,048 Views)
Thanks for the link but when I try it it does not seem to work. I'll try going manually to the link via the forums.
(4,027 Views)
Hello Keith,
Apparently the brackets were accidentally included in the link. Here's the right one:
Kind Regards,
(4,020 Views)
