Harmonically distorted waveform
hi
i have a VI which is able generate and show a series of harmonics (simply the fundamental, 3rd & 5th). What i want, however, is to produce another sine wave in another graph and show the affects of it when adding these harmonics. Basically by adding these harmonics the sine wave becomes distorted. I've attached a docx file which includes snap shots of the block diagram, the front panel as well as an example of a pic of a harmonically distorted sine wave. /.
any suggestions are welcome.
thanks
(3,813 Views)
Take a look at this
Randall Pursley
(3,795 Views)
hi there
thanks for the response. im unable to view the vi because its a higher version than the one i have. is it ok that you can convert it to an 8.5 or less? much appreciated.
(3,790 Views)
This should be 8.0
Randall Pursley
(3,776 Views)
no sure if you got my pm but it's still not opening because it's a higher version than 8.6.1.
much appreciated if you can just send in a snapshot or a 8.5 vi.
thanks
(3,759 Views)
Sorry  about that.  This should be 8.5 now.
Randall Pursley
(3,741 Views)
hiya
thanks very much, it works now.
im also wondering if there's anyway way that i can manipulate the harmonics voltage sample - say if the fundamental is running at 2V but i want the 3rd or 5th to be running at 10% of that (i.e. 0.2V), how do i go about that. again any suggestions are welcome.
(3,709 Views)
