Hardware Timed Single Point Data Acq with PCI-6143
Ryan,
Are you consistently missing the same point, or is the location and / or occurrence of the missing pulse random? Also, did you try Micaela's suggestion of modifying a shipping example to use timing from the RTSI bus?
Ryan Verret
Product Marketing Engineer
Signal Generators
Message 21 of 25
(884 Views)
It is not always the same point in the array.
I am using the RTSI bus to route the signal from the FGen to the S-DAQ.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 22 of 25
(880 Views)
Ryan,
Could you post the smallest amount of code that exhibits this behavior? We will look into it on this end.
Ryan Verret
Signal Generators
Message 23 of 25
(871 Views)
I figured out with the help of a coworker that it was a memory allocation and handling issue.  When I was using shift registers in my one loop of my validation test vi it was missing points.  When I created another vi and used queues to transfer the data to a data handling loop, reduced the data and stored it, then discarded it from memory - I did not miss any points.
Message 24 of 25
(862 Views)
Ryan,
Glad to hear you got it working. Good luck with your application!
Ryan Verret
Signal Generators
Message 25 of 25
(860 Views)
