01-16-2017 02:48 PM
I am trying to create a VI to read an NI DMM using 64-bit LabVIEW 2015. I can place the configure DMM VI from the measurement I/O functions pallet. When I right-click, and try to create a control for the intrument handle, LabVIEW crashes. I get a pop-up dialog that tells me LabVIEW 15.0.1f2 Development System has stopped working.Other instruments I tried seem to have the same problem.
Everything seems to work fine in 32-bit LabVIEW, so as a work-around, that's what I am doing. I am calling the VIs in 64-bit TestStand, but I just changed the adapter settings to use 32-bit LabVIEW, and that seems to work.
I tried reinstalling NI-DMM, but that didn't fix the issue.
Can anyone tell me why I can't use 64-bit LabVIEW with the measurement VIs?
Solved! Go to Solution.
01-17-2017
08:46 AM
- last edited on
11-04-2025
01:10 PM
by
Content Cleaner
Hi Jo-Jo,
What OS are you using? It is surprising that you are seeing this behavior with LabVIEW 64 bit. Generally speaking, if you can use the 32-bit environment, it is strongly recommended to do so.
LabVIEW 64-bit vs. 32-bit Applications
What specific DMM driver are you using? I would recommend using NI DMM 15.2 if possible to have the most updated version of the 2015 driver.
NI-DMM 15.2
https://www.ni.com/en/support/downloads/drivers/download.ni-dmm.html#324119
I have a few other thoughts of ways to troubleshoot. Pending your response we can take action accordingly.
Finch Train
01-17-2017 12:13 PM
Sorry, I forget to mention the OS. I am using Windows 7 64-bit. The DMM is the PXI-4070.
Why is it recommended to avoid the 64-bit version of LabVIEW?
01-17-2017 01:46 PM
01-17-2017 02:04 PM
Jo-Jo,
That is definitely not expected behavior. 64-bit LabVIEW is typically very stable, as is NI-DMM (in both 32-bit and 64-bit processes), particularly for such a basic use case.
Particularly since you're seeing the issue with more than just NI-DMM, I suspect that your LabVIEW installation may be corrupted. This will take a while, but I would recommend running a repair of LabVIEW and NI-DMM from Windows' "Programs and Features" (formerly Add/Remove Programs), and if that still doesn't fix it, a repair of all National Instruments software.
Alternatively, you may also want to try upgrading LabVIEW 2015 to the latest dot release. You can do so by using the NI Update Service. This will also allow you to upgrade other installed products (such as NI-DMM) to their latest released versions as well.
01-17-2017 04:45 PM
I'll have to try to fix the installation later. I did need 64-bit LabVIEW because I was collecting and analyzing tons of data, and I kept running out of memory, but I'm past that, and now 32-bit will work for what I am doing.
Thanks for the help.
