Hard to explain problem
I have a problem i can't put into words (maybe there is already a topic, but i can't find it) so, see the attached image.
Message 1 of 22
(4,419 Views)
Adding an image is good but that either explains the problem. Please explain with that image what is the problem you are facing.
Message 2 of 22
(4,404 Views)
Image looks good Smiley Wink
so what are we all suppose to do with it?
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 3 of 22
(4,403 Views)
I want to move (in this case) the first 3 elements behind the last elements, the index becomes bigger, that is important, because I want to take an average form the index with an 1 as element.
Message 4 of 22
(4,392 Views)
Check out the Rotate Array function.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 22
(4,386 Views)
Hi henk,
- get a subset array from your first 3 elements
- append it to your existing array with BuildArray
- replace the first 3 elements by zeros
That is what you should do based on your image and explanation…
@Yamaeda: RotateArray doesn't increase array size. You might rotate and prepend 3 addtitional zeros in front…
Message 6 of 22
(4,374 Views)
Tanks a lot! I will give it a try
Message 7 of 22
(4,364 Views)
Do I have to use the concatenate function in builarray?,
Message 8 of 22
(4,354 Views)
Yes. Otherwise you add a new dimension to your array…
Message 9 of 22
(4,352 Views)
and how do you replace 40 ones into zeros?
Message 10 of 22
(4,345 Views)
