Handling the array
Jagan,
What's the point in preallocating an array if you're not using shift registers and replace array subset to modify it? Probably you're still generating the array in the while loop.
Can you post your code?
Daniel
Message 11 of 13
(829 Views)
Previously i have used some condition based data filling which i made it complex and not able to use shift register.
Now Im using the shift register and Replace ArraySubset.vi properly. now Data is filled with in few second.
Thanks to all for your kind support...
-Jagan
Message 12 of 13
(797 Views)
Hi Jagan,
Is your problem solved? If so please mark (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 13 of 13
(789 Views)
