Hall effect Current Sensor output
Hello everyone,
I am using an birdectional hall effect current sensor to measure the current in a battery cell. The output of the sensor is connected to an PLC . The sensor ouputs the measured current in the range of 4 -20mA and it can measure a maximum of 25A. i.e  4mA= -25A and 20mA= +25A. The PLC is reading the corrct value as i have checked it. when no current flows through it it shows approximatley 12mA, which  represents 0A. Now my question is, how can i programme in such a way that labview changes the measured value into actual current value in Ampere. i.e when the signal outputs 20mA, i want the labview programme to show as 25A in the front panel. Is this done using scaling and if so, can someone explain how it´s done.
Thanking you
Gokul Gopakumar
(2,341 Views)
Hi Gokul,
So you are asking for some basic math lessons? Really?
You know those XY points:
signal  current
 mA        A
  4      -25
 12        0
 20      +25
And now you are looking for the calculation to convert the 4-20mA signal into the measured current (±25A)?
What about a simple linear equation:
current := (signal - 0.012)/0.008 * 25
or
current := 3125 * signal - 37.5
(2,316 Views)
Hello Gerd,
Thank you for the clarification. Umm is the formula right?, because when im using it i am not getting the right values.
Thanking you
Gokul Gopaumar
(2,284 Views)
Hi Gokul,
I get correct values with my formulas!
Remember: your signal is in mA, so you get readings like 0.006 or 0.0195...
(2,271 Views)
