HTTPS/SSL Support on Realtime
I have an application that is using HTTPS commands (like GET and POST).  It works fine on Windows, but it appears that HTTPS/SSL is not supported on Realtime targets (I get error 1596, 'Cannot use SSL on this operating system because SSL is either not configured, not installed, or not supported.').
1.  Is this the case?
2.  And if so, if/when will this be supported on Realtime targets?
Thanks.
(3,158 Views)
This is not the case. VXworks (cRIO's operating system) supports SSL. You need to install this feature in your device.
Miguel Fonseca
(3,142 Views)
Thanks.  I thought I had checked the installed software, but forgot to push 'HTTP Client with SSL Support' to the RT.
-Joe
(3,138 Views)
