HTML preview on front panel
Hi!
Is it possible to preview a text that contains HTML tags on the front panel as HTML?
I'd like to see my html report result before i save it into file.
(4,172 Views)
Hi wasz,
yes it's possible. You can use the ActiveX WebBrowser.
Mike
(4,167 Views)
Hmm! Thanks!
And how portable is it? Does it work if i build an executable from my project and then use it on another PC? I guess that the only requirement would be the same browser on that machine.
I found an example in LV, using IE with activex. Did you mean that?
(4,160 Views)
One more question.
I tried it and it works for URLs, and HTML files on my hard disk, but i would like to use it with strint constants that contain HTML formatted text. I do not want to save it first. is IT possible with this?
(4,154 Views)
Accepted by topic author wasz
Hi wasz,
afaik it's not possible. You can only load urls or files.
Mike
(4,147 Views)
ok.
Thank You!
(4,145 Views)
