HSDAQ Sampling
Hey,
I am sampling data using the NI HSDAQ (BNC - 2110). The input stream is coming as 16-bit signed integer samples. I wish to convert this stream to to strings/numbers and output them into a text file. The program can make the text file, however, it seems the program isnt outputting the correct data. Shall be grateful for help.
Pash
(2,704 Views)
Hi Pash,
Is there any indication that you are aquiring the data you expect? Is the input stream that you are attempting to write to file correct?
How are you attempting to convert the signed integers to string format? You may want to consider using alternative methods from the String/Number Conversion subpalette.
Cheers,
Emilie | Applications Engineer | National Instruments
(2,686 Views)
