HRV Measurement to find R-R interval
Hi Steve,
Thanks for replying, actually I am using contactless coupled ECG which has active sensors for measurement of ECG parameters in car seat integration. I am acquring real time measurement from my data acqusition device which has a
sampling rate of 1k, and no of samples is 5k, ie I am measuring for a period of 5 seconds. I want to display Heart rate in beats/min and then find heart rate variability ie the distance between two R-R peaks and plot them.
I adopted the same method as mentioned in one of the article-- Labview for ECG signal processing,  I am not able to get heart rate correctly. Kindly have a look at my attached vi, where I have sample data and also data from a conventional ECG.
Thank you,
abi
Message 11 of 14
(2,732 Views)
I was wondering if you could resave and post your VI for labview 7.1  I have constructed a VI for HRV analysis, but am have quite a bit of difficulty getting a "usable" PSD from my resampled RR interval data.  I only have labview 7.1, and have read the NI article on HRV (many times).  I could really use the help.  Thanks.
-hgurji
Message 12 of 14
(2,635 Views)
Hi infra444
I am using the pulse signal to analyse HRV and am ahving some issues with Power spectral density calculation.
I need to remove baseline awndering and WA detrend.vi in the advanced signal processign toolkit (which I dont have) seems to be the suggested apporach by NI.
Is there away to remove this using  standard labview function.
Have u calculated PSD in your analysis?
Message 13 of 14
(2,533 Views)
For removing the trend, you could use a high pass filter such as Butterworth.
Message 14 of 14
(2,514 Views)
