08-02-2010 04:55 AM
I was wondereing whether anyone knew if you could do a sweep up and then back down using the HP4145A? Is it possible with auto sequence? Or some other way? And is it possible to then programme that into LabView....... for now i'll keep browsing the user manual...
08-03-2010 03:31 AM
Hi Pazmush,
Thanks for posting, I would recommend working of the community example linked in below.
http://decibel.ni.com/content/docs/DOC-1164
It looks like someone has already written a LabVIEW VI for this instruments which could be modified for your application.
Best of luck,
