HP 83652A connection problem
         I'm using LabVIEW 2009 and have installed NI device drivers(NI-488.2).I've connected HP 83752A synthesized sweeper to the PC through GPIB cable.The GPIB address of this instrument is automatically showing up in the VISA open function.The problem is in the Agilent I/O connection expert,under Instrument I/O on this PC this instrument address is showing up with a Failed symbolbefore it saying there was  a communication failure.Even If I send *IDN? string I'm getting "There was a communication failurae as response".can any one help me out
Regards
RobinHood
(2,921 Views)
Why are you using the Agilent utility? Since you have an NI controller, you should use MAX.
(2,917 Views)
thank you fo your reply.can you please tell me what to do in Max
Regards
RobinHood
(2,914 Views)
To do what? Just communicate to the instrument? If so, right click on the instrument listed there and select 'Communicate with Instrument'? You can also select Tools>NI-VISA>VISA Interactive Control.
p.s. Going to the Help menu is also a good idea.
Edit - you must also install NI-VISA.
Message Edited by Dennis Knutson on 03-09-2010 06:13 AM
(2,910 Views)
