HOW to create a source code in NI like c language
Instead of creating a subvi( which has many controls and indicators ) and i make the code as a source code and add in the main code like in the case structure.
please if possible explain with help of a example
(3,779 Views)
Ummm.... what? I'm sorry, but your question is not clear at all. Are you asking if it's possible to generate C code from LabVIEW? Are you asking if it's possible to use C code in LabVIEW? Are you asking how to use the formula node, which has a C-like syntax?
(3,774 Views)
Scratching my head.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,743 Views)
LabVIEW Windows/CVI may be a choice if you are customed to C.
(3,719 Views)
The front panel of a sub-vi are optimized away when compiled, so they dont affect the result. If you dont want to see the sub-vi you can select "Inline subvi" in LV2010 which'll place the sub vi's content instead.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,692 Views)
Maybe you don't understand.  In Labview, the block diagram is the source code.  Its graphical, not text.  You cannot create text source code in Labview.  I don't see how a mere subvi icon in your main VI would not be acceptable.  It's like making a function call in C.  It takes a line of code to make a function call in C.  It takes a little space on the block diagram for an icon to make a subvi call.  You need to get used to the graphical concept and forget about text.  This may be why you have lots of control and indicators.  Unlike in text code, you don't need to create variables to hold the values of each and every operation.  Wires take care of passing the output of one function directly to the next funtion without the need for controls or indicators or local variables.  Maybe you should post your vi here so we can give you some pointers.
- tbob
Inventor of the WORM Global
(3,657 Views)
