HOW can i use case structure?
if (ibsta & 0x8000)
    testData->replaceStringFuncPtr(&testError->errorMessage, errorMessage33120A);
          testError->errorFlag = TRUE;
          testError->errorCode = ibsta;
    return;
        else
how can use case structure like if else  when fail case i need do nothing.
    in my attached
    i want to find the elemet of array include"input",but  output include blank array,because the false can not be empty.
thanks for you helps
Sonic
Diffrent Strokes for Different Folks
(3,124 Views)
You use a shift register like in the modified VI attached. A very similar example ships with LabVIEW. It's Fundamentals>Arrays and Clusters>Separate Array Values.
(3,105 Views)
wonderfull !!!
thanks of your hepls
Sonic
(3,080 Views)
