HOW TO Unflatten From JSON Function
I tried to decode but couldn't, please help me!
{ "data": { "PGAList": [ {"staCode": "D001", "pga": 8.848}, {"staCode": "D002", "pga": 5.751}, {"staCode": "D003", "pga": 5.469}, {"staCode": "D005", "pga": 4.347}, {"staCode": "D006", "pga": 6.411} ] } }
(4,529 Views)
Accepted by topic author koukileo
Assuming you set the correct labels, you only need to change pga from string to double.
(4,517 Views)
I found out that I had other setup issues. But your reply saved me a lot of debugging time. now i'm done
(4,499 Views)
I see your immediate issue is already solved, but I just thought I would note that the native LabVIEW JSON is a bit "fragile" in that the cluster passed in has to match the JSON exactly or you get nothing at all.
For you or anyone else who comes along later, I would recommend considering using an alternate library.  I've had good luck with this one:
https://www.vipm.io/package/jdp_science_jsontext/
It's slower but a lot more tolerant of minor JSON changes and will give partial decodes rather than nothing if the format is close but not exact.
(4,443 Views)
Ok thank you for your help, I will try to see what you said. Have a nice day
(4,393 Views)
