HOW TO SEE AN IMAGE SPLITTED IN 2
THIS VI IS SUPPOSED TO HAVE A VIDEO INPUT THEN CONVERT IT INTO AN ARRAY TO THEN DIVIDED THIS IMAGE IN 2. THE FIRST HALF IS SUPPOSED TO SHOW THE RIGHT SIDE AND THE OTHER HALF THE LEFT SIDE OF THE VIDEO. HOWEVER I HAVE A PROBLEM DISPLAYING BOTH AT THE SAME TIME. IF I CONNECT ONE AT THE TIME IT WILL WORK BUT IF I CONNECT THOSE 2 TO THE SOURCE IMAGE AT THE SAME TIME, I WILL ONLY SEE ONE SIDE EITHER RIGHT OR LEFT SIDE. CAN ANYONE  OFFER A HAND? PLEASE.
Message 1 of 14
(4,109 Views)
Accepted by topic author NEVCH
Check your CAPS LOCK key.  It seems you have something wedged under it causing it to stick on.
In order to work with two copies of your original image, you are going to have to use the IMAQ Copy VI.
Message 2 of 14
(4,106 Views)
I tried to do what you suggested but I didn't work, I still get the same result as before. I don't know what else to do.
Message 3 of 14
(4,078 Views)
Then post your latest VI.
Message 4 of 14
(4,074 Views)
While diaplaying you will need to define invidual buffers (IMG DST) by connecting imaq create with different names. I am not able to view your vi as i am still stuck with 8.0. So if you can then post it for 8.0/post a screenshot.
Message 5 of 14
(4,069 Views)
As you can see from my vi, I am pretty new doing this. I actually have 2 weeks and half trying to learn solo. Hopefully you can see where I am making the mistake that probably is very silly. Thanks in advance.
Message 6 of 14
(4,064 Views)
Here is a picture. This vi is actually inside a for loop, but that is the most important part.
Message 7 of 14
(4,063 Views)
You have connecte a img control directly to image dst in img copy. It should be a reference of an image. Wire a proper bufferred (imaq create) reference.
Message 8 of 14
(4,059 Views)
Hi NEVCH,
apart from your IMAQ problem:
There is a ArrayMinMax function that will do what your two big double nested for loops at the right do Smiley Wink
Message 9 of 14
(4,050 Views)
In one of my many attempts, I wired an IMAQ create to the Img Dst of the IMAQ while wiring the input of the IMAQ create to my image output that is labeled as Image 300x300 in my vi. It didn't work either. I still get to see only one side of the picture in both image outputs.
Message 10 of 14
(4,036 Views)
