HOW TO PLOT FILTER CHARACTERISTIC CURVES
I  need to compare the curves of different order of filters, how can i plot out the filters curves in LV?
I 'm thinking allow a constant array pass through the filters and i would get the filter curve, but i got weird result. say, when i set it to be low pass,
the outcome looked like high pass curve.
(3,738 Views)
could you give more info?
like the filter you are using , a sample of data you want to filter and also attach the VI you are using and a snapshot of what curve you are getting.
regards
Dev
(3,730 Views)
I 'm writing thesis, I need to show the chracteristic response  curves of different filters( like Butterworth, Chebychev), just to show the difference!
I don't want really filter some data, and I don't want to plot the filter response curves from mathematic equations
that's what I mean.
attached is waht I tried, but the curves come out looking weird!
(3,726 Views)
You're doing a thesis on how a filter responds to DC? That's the signal you're inputing to the filter functions.
(3,721 Views)
Generate a signal using any function generation VI's present in Labview and feed it to filter by selecting suitable filter settings.
Basic function generator.VI should do the job.
regards
Dev
(3,705 Views)
What you are doing is using the filter to process a step signal u(t), then the result is the step response, which is the time-domain characteristics of a filter.
According to what you have said, you want to plot the frequency response of a filter since you are expecting a highpass curve.
The frequency response of a filter is the frequency domain characteristics of a filter. You can get it through filtering a impulse signal which has a flat spectrum and then computing the filtered-signal's spectrum.
Attach a simple VI to illustrate it.
(3,652 Views)
