HOW TO MAKE EXECUTABLE STAND ALONE APPLICATION IN LABVIEW
HELLO
I AM TRYING TO MAKE STAND ALONE APPLICATION, I ALSO TRIED TO FOLLOW THE FOLLOWING LINK
http://zone.ni.com/reference/en-XX/help/371361D-01/lvhowto/building_a_stand_alone_app
THE PROBLEM I AM FACING IS I AM NOT GETTING THE "NEW>>APPLICATION" . SO URGENTLY NEED HELP
ANOTHER QUESTION IS I AM TRYING TO MAKE A LIST OF BUTTONS WANT TO BE USED IN SEQUENCE. MEANS FIRST BUTTON IS ENABLED TO BE PRESSED WHILE OTHER ARE DISABLED AND GRAYED UNTIL THE PROCESS BEHIND THE FIRST BUTTON IS DONE AND FINISHED....
THANKS IN ADVANCE
Message 1 of 20
(4,846 Views)
you have to tell which version of labview you are using. Also whether its a licenced or evaluation one? give bit more details.
Message 2 of 20
(4,843 Views)
 For your first question tell your labview version & for the secand use property node.Hope the attached Vi helps.
Message 3 of 20
(4,837 Views)
You also need to make sure you have the edition of LabVIEW that has the Application Builder. This means you need to have either the "Professional" edition, or you need to have purchased the Application Builder as an add-on.
Message 4 of 20
(4,808 Views)
Thanks Geeta
for the help in my second question
V8.5 labview
Reg on Professional Development System
Message 5 of 20
(4,787 Views)
All right, let's double-check a few simple things.
(1) You're right-clicking on the "Build Specifications" item, correct?
(2) What do you get when you right-click on the "Build Specifications" item?  For the "New" menu item, what do you see?
Message 6 of 20
(4,780 Views)
For future posts, please turn off the CAPSLOCK
[will work for kudos]
Message 7 of 20
(4,773 Views)
Hello Thank you people Reinstalling Labview solved the problem...
Question make question now I have another query I am calling subvi's what change will help me to open the subvi in same window instead of another windows and how can I arrange my graphic at origin (0,0) of screen. means i have to maximize the window.
Thanks again for your help ppls
Message 8 of 20
(4,753 Views)
Hi.....
          For setting the origin of a FP pls go through the below link as it has already been discussed.Hope that helps you in a better way. And you cant call a subvi in the same window, what you can do is use a system boolean button hide the main screen Fpanel when you call a subvi. Let me known if any issues.
http://forums.ni.com/ni/board/message?board.id=170&message.id=359699#M359699
Message 9 of 20
(4,749 Views)
AutoTEC wrote:
Hi.....
Yes, you can. SubPanel.
Message 10 of 20
(4,715 Views)
