HOW TO EXTRACT DATA FROM SPREADSHEET?
Good morning guys... I need to extract data from an excel spread sheet is there anyone who can be able to help me?
rgds
thulani
Message 1 of 16
(4,380 Views)
Hi.
Have You tried searching the LabView Examples???
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 2 of 16
(4,377 Views)
I tried but can`t get exactly what im looking for...
Message 3 of 16
(4,375 Views)
Hi 1235,
what about the "read from spreadsheet file" function. Or do you mean a "real" *.xls file. If yes you can use ActiveX functions.
Mike
Message 4 of 16
(4,371 Views)
What exactly are You looking for then.
A more Thoroug description than "Need to extract data from Excel" would be nice. Smiley Happy
Message Edited by BCL@Servodan on 05-29-2008 02:27 AM
But there's NOT
LabVIEW 2012-2017
Message 5 of 16
(4,370 Views)
Hi again.
Try this attachment, it might help.
Message Edited by BCL@Servodan on 05-29-2008 02:34 AM
But there's NOT
LabVIEW 2012-2017
Message 6 of 16
(4,365 Views)
hi Mike...will try to it in that way. the fact is that im still new in labview environment. i`ve been told to log data into a spread sheet, yes i can do that, but it continues saying that after the data has been logged you must be able to extract certain values and send it to another spread sheet.
Message 7 of 16
(4,360 Views)
Hi Mr Wise,
what will you try, "read from spreadsheet" or "activex"? Can you explain? Can you upload your vi? What type of values do you want to write, strings or numbers?
Mike
Message 8 of 16
(4,333 Views)
thanks. The information that I want to extract is a string, let me send you the file so that you can see exactly what am I trying to say....Attached is the file.
Message 9 of 16
(4,324 Views)
Hi Mr Wise,
how long will your loop "normaly" run? You can build an array of your data which you want to write to the file. Use the autoindexing function of the loop for it. Then you can use the "write to spreadsheet file" function, there you can connect directly your array. Which version of labview do you use?
Mike
Message 10 of 16
(4,321 Views)
