HOW TO EXTRACT DATA FROM SPREADSHEET?
Im using Labview 7.1, would you mind taking me through the steps, just to give me the instruction on how to do it. Im still new in the labview world..lol
Message 11 of 16
(1,223 Views)
Hi Mr Wise,
here is an example. Hope it helps.
Mike
Message 12 of 16
(1,218 Views)
Thanks man, will try it and see what I get...will let you know the results.
Message 13 of 16
(1,215 Views)
Hi mike!
Tried to work out the example you gave yesterday, but i don`t get exactly what am looking for. let me  rephrase my question. " After the data has been logged you are required to extract data where the temperature values exceeded the value of 29 or below 23" this must also show time and date.
Message 14 of 16
(1,185 Views)
Hi Mr Wise,
to do that, you can build an array inside the loop an auto index that, or you auto index first both outputs and build then the array. The result is a 2d array which you can write to the spreadsheet. If you read the data you get the 2d array, index the row/column you need search for your values and index the corresponding time/data information from the other row/column.
Mike
Message 15 of 16
(1,183 Views)
Thanks mike, where are you situated, im based in capetown(SA)
Message 16 of 16
(1,175 Views)
