HOW TO ENTER CALIBRATION CHART FOR LOAD CELL
We have a HONEYWELL LOAD CELL,MODEL NO 31,100 LBS,we have the calibration chart,how we can give those data in labview.
(3,075 Views)
Since you know the make and model of the equipment, you should be able to find the manual.  Find out at least how to do it manually - better if you can find out how to do it programmatically.  Once you do this, we can assist you in the translation to LabVIEW code - if you still need help by then.
Bill
CLD
(Mid-Level minion.)
(3,050 Views)
we have make this code ,now help me how to enter the calibration chart
(3,046 Views)
Hi tendoraj,
So you set up the DAQAssistent to read a signal from a bridge-type sensor and already configured scaling to output "pounds" instead of just "voltage": I guess you already used the calibration sheet to determine the scaling parameters?
Which other parameters of that sheet are important to you?
Btw. which scientist is using "pounds" for scientific data? (Asking from a European metric system point of view. :D)
(3,037 Views)
Who says he is a scientist?
Pounds a a perfectly good engineering unit.
Spoiler
There are two kinds of countries in the world.  Those who use the metric system, and those who put a man on the moon!  😉
(3,030 Views)
Hi RavensFan,
When I hear/read of "pounds" my first thought is "Which one?"…
Wikipedia names two different pounds usually used today. Both of them are different to the current German "pound", used nowadays (and since ~170 years). The German Wikipedia lists about 3 dozen (a nice non-SI unit 😏) different historical "pounds", just for the area of medieval Germany. And I only use troy pound (or mostly troy ounce) because the price for precious metals is given in this unit…
Spoiler
And because some (US) people used "pounds" a space probe crashed on Mars… 😁
(3,004 Views)
@GerdW wrote:
Spoiler
Actually, the entire story wasn't as simple as that explanation.
(2,983 Views)
