HOW TO COMMUNICATE ARDUINO UNO WITH LABVIEW
Hello All,
I am given an arduinon uno with BMP 085 (Barometric Pressure sensor) to measure the temperature and pressure. I was able to wire the arduino with sensor and code with c. It runs fine on arduino driver and gives the output. But I am also asked to display my result through waveform chart on LBVIEW. I am new to labview and not being able to create VI to communicate my arduino device with it and display the result. I would really be so thankful to any help provided on this topic or if someone could attach a VI that could make my job easier. I need to display temperature and pressure .
(3,844 Views)
I would suggest that you could use LIFA. The best place to post your questions is on that board as it is a thriving community dedicated to using LabVIEW with the Arduino.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,829 Views)
There is a group in which topics of arduino arduino
https://decibel.ni.com/content/groups/labview-interface-for-arduino
You can ask your questions, example code attached
(3,655 Views)
