HOST AND RT Target application architecture
hello,every one
         I use a computer as host tocommunicate with PXIe-1075 chassis,as follows. but, I do not how to do at software .so ,can you help me or give me some suggestion? if you give me some course i will be deeply grateful.
(3,371 Views)
There are a lot of different methods to communicate between two computers across the network. This help page goes over some of them.
https://www.ni.com/docs/en-US/bundle/labview/page/data-communication-methods-in-labview.html
Some questions for you would be, what type of information to you need to transfer between the computers? Is this always going to be a 1:1 between computer and RT? Are you communicating between 2 LabVIEW applications and will this always be the case?
(3,350 Views)
Jacobson 已写:
I need to transfer the acquisition data(temperature sensor,pressure sensor and so on ) to computer and output  control signal to RT to control analog output and digital output. I am used this architecture at Automation  test. Yes, I always going to be a 1:1 between computer and RT.YES.
By the way, I could not find the example of the link you give me.As follows.can you tell me how to find a  full architecture about  automation test.
(3,328 Views)
The two methods I use to communicate with an RT system are TCP/IP with the STM library and Network Streams.  There are plenty of examples floating around for Network Streams (look in the Example Finder built into LabVIEW).  And the STM comes with a simple example.
(3,296 Views)
