uit board which needs to be tested mounted on a test fixture. The pins of the curcuit board need to be given certain voltages from LabVIEW to verify some tests.But,my signals dont go to those input pins of UUT eventhough my program doesn't have any errors.Hi,
As you described that when you dont connect anything on DAC0 channel of PCI-6040, you are getting the right voltage. But when you connect to your test fixture, no voltage appears there. I feel, test your signal output step by step, i mean that just try feeding DAC0 output to some other test fixture or uut, observe the issues. Or instead of feeding the DAC0 output directly to test fixture, feed it in one of the module if your test fixture is modular & can be separated into various parts or stages. I think you need to debug your test fixture on each stage of your votlage path.
Hope this works. Your feedbacks are welcome.
Best Regards,
Nirmal Sharma
India
