HEX to ASCII
Hello everyone,
this is a stupid question......
How do I convert an HEX code to an ASCII code in labview? The device sends
me a CAN message with the data that I need but it sends it to me in an HEX
code. After I've received the message, I need to convert the HEX code to
an ASCII code.
ex : the first byte of data contains the HEX code 31, now I need to convert
it to the ASCII code which is 1, and so on with whatever code I receive.
I've looked everywhere in labview but I can't find what I want to do.
Thx
Eric Paulin
(4,290 Views)
nevermind this message I found it......
byte array to string.....that's it.... I told you it was stupid.....:)
Eric Paulin
"Eric Paulin" wrote:
>>Hello everyone,>>this is a stupid question......>>How do I convert an HEX
code to an ASCII code in labview? The device sends>me a CAN message with
the data that I need but it sends it to me in an HEX>code. After I've received
the message, I need to convert the HEX code to>an ASCII code. >>ex : the
first byte of data contains the HEX code 31, now I need to convert>it to
the ASCII code which is 1, and so on with whatever code I receive.>>I've
looked everywhere in labview but I can't find what I want to do.>>Thx>>>Eric
Paulin
(4,289 Views)
Eric Paulin wrote:
> Hello everyone,
> an ASCII code.
> Thx
> Eric Paulin
Eric it's simple. Most likely you receive your data in a string.
Right-click on this string indicator and choose normal/hex display.
If you get bytes in U8 array(?), wire it to
function and see your "1" in a string indicator as an ASCII symbol.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(4,289 Views)
