06-20-2009 09:59 AM
I tried but none of the exemples work . I need a simple vi that detects motion and a green light is on when that happens . The method is not important the easyer the bether (treshold is easy not STEI or segmentation). Thanks
06-20-2009 06:05 PM
06-22-2009 09:30 AM
Are you able to acquire images in LabVIEW with your web camera? I'm assuming that this is s USB camera which means it will have to be DirectShow compliant to work. Additionally, you will need the IMAQ for USB driver which can be found here: http://zone.ni.com/devzone/cda/epd/p/id/5030 . Which examples have you tried? There looks to be a good one on the community here: http://decibel.ni.com/content/docs/DOC-4717 . You will have to fix the code in the example so that it uses the IMAQ for USB driver instead of IMAQ or IMAQdx.
-Zach
06-22-2009 11:56 PM
