06-24-2010 03:06 AM
06-24-2010 02:52 AM
Hi all,
Im new to labview and am not sure how to perform the correct integration of a signal. The problem i have is that after integration the signal is offset by a value. I know this is due to the antiderivative of the function is the sum of the antiderivative plus a constant C. I tried to remove this offset by measuring the dc value and subtracting it. The problem is that the resuslt is a scalar value and not a waveform. The integral of a sine signal should give me -cos +c signal and i just want to remove the constant c and obtain the -cos waveform. Which VIs should i be using?
06-24-2010 03:21 AM - edited 06-24-2010 03:22 AM
06-24-2010 03:39 AM
