HELP for saving data
Everytime I reopen a VI, the data in array automatically goes back to 0. Why is that? How do I change that?
(3,264 Views)
I assume that you are talking about an array control on the front panel. Put the data into the array. Then from the Edit menu select Make Current Values Default. Save the VI.
Now the data will be in the array every time you open it.
Lynn
(3,251 Views)
Yes. It worked. Thank you.
(3,242 Views)
