HELP WITH GENERATE RANDOM FLOATING NUMBER
Okay, thank you so much. I really appreciate it!.
Message 11 of 13
(482 Views)
Thank you so much for your reply. you are so awesome!
Message 12 of 13
(482 Views)
@aeastet wrote:
I would use the point by point max value. That is what you said that you were looking for. You can use the built in function to increment for the iteration count.
I'm not a fan of the Max & Min PtByPt VI just due to the overhead it has inside of it when it comes to the goals we are after here.  If you wanted a Max value over the last X samples, then I would use the PtByPt VI.  But for a max value over all acquired, a simple shift register does the job quite well.
GCentral
Message 13 of 13
(480 Views)
