The following thread seems to address a similar query:
http://forums.ni.com/ni/board/message?board.id=170&message.id=27248&requireLogin=FalseTo answer some of your other questions:
1. You'll be communicating with the Mitsubishi hardware using an OPC server.
2. This isn't the same as the device drivers, though it could be included with the device drivers you got from Mitsubishi, you would have to check that with them.
3. I don't know if you need a profibus network card in your machine, again, you'd have to check that with Mitsubishi
NI do provide OPC software but I'm not sure if your device is supported. Check if it's listed in the following
supported device list. If not you should be able to get an OPC server from Mitsubishi. According to the thread linked above they have one that's compatible with LabVIEW.
The software NI provides that can communicate with OPC servers is called the Data Logging and Supervisory Control Module. What LabVIEW software do you currently have?
I would advise that you contact Mitsubishi to make sure you have all the necessary hardware first. Also, ask them about the OPC server software. Then you can work on controlling the PLCs with LabVIEW.
I hope this clarifies things but if not, post some more questions.
Sarah
Applications Engineer | National Instruments | UK & Ireland
