HELP: Run-time array dimension in LabVIEW formula node
I need to dimension an array at run time within a formula node as follows:
int32 i,N;
N = sizeOfDim(inputArray,0);
float64 outputArray[N];
for (i = 0; i outputArray[i] = myfunction(inputArray[i]);
However, LabVIEW complains "Formula Node: index list expected". On the
other hand, if I say
float64 outputArray[1000];
LabVIEW is perfectly happy. But that's not what I need to do! Is there
an alternative
way of accomplishing my goal?
BTW, I've tried calculating N outside the formula node and then
presenting it as
an input with the same results. I've got a bad feeling that run time
array dimensioning
just isn't allowed.
TIA,
Hugh
(3,007 Views)
Can't you just use the Initialize Array function outside the formula node and pass that instead?
(3,007 Views)
